Editing profile - flash required!
Posted by: Jasonf on 27 February 2013
Chaps,
just tried to edit my avatar, I received the message, "you require Flash to enable this function press here", then I received the message "this device does not support Flash" and of course as I was on an IPad mini, it's not supported by Apple any more.
So how does one go about editing the avatar on an Apple device?
Jason.
Posted on: 27 February 2013 by Richard Dane
Jason,
if you're having difficulty and don't have access to a flash enabled computer then send the image via e-mail to Naim and ask Steve Hopkins to change it for you or forward it on to me so I can do it for you.
Posted on: 27 February 2013 by Jasonf
Hi Richard, I have a pc here, thanks for that.
Jason.
Posted on: 27 February 2013 by Steve J
Jason,
It may not work on an iPad but does on a MacBook.
Steve
Posted on: 27 February 2013 by spartacus
Originally Posted by Steve J:
Jason,
Steve
Sure does Steve. OSX runs Flash, iOS doesn't.
Jason,
Steve
Okay chaps, thanks.
Jason.
