Recommendation for an external CD drive?
Posted by: jfritzen on 06 March 2013
I recently bought a new Mac mini. And since the new iMacs, MacBooks and Mac minis don't have internal optical drives anymore I need an external CD drive for ripping. Can anybody recommend something that's reliable and fast and works with a Mac (XLD to be precise)? USB powered would be nice but is not mandatory.
KR
Jochen
Posted on: 07 March 2013 by aht
In my experience, the standard Apple external drive works very well and is reasonably priced.  Opinions here may differ, however.
Posted on: 07 March 2013 by BrendanD
I'm a big Apple fan, but I must beg to differ here..... Its rubbish.
I've owned three of these over the past few years, OK one died after dropping it, but I just used a new Superdrive to rip 350 CDs. 30 of them failed to read, and it was getting progressively worse, so one disc in 4 was failing. I've just replaced it with a Samsung SE-208 and read all my failed discs.
It was also half the price.....
Posted on: 07 March 2013 by pjl2
I've no idea if it will work with a Mac, but I use a slimline Samsung drive (cost around £30 a few years back) and it has worked brilliantly for ripping and burning CD's and DVD's - no problems at all. I must say though that if I owned a Mac I would go for Apple's own drive, which is surely optimised for use with their computers.
Peter
Posted on: 07 March 2013 by jfritzen
Thanks so far. Regarding Apple's SuperDrive, I've read some negative comments on amazon. But I think a Samsung drive will be OK.
Posted on: 07 March 2013 by mikapoh
Seems like Samsung is the preferred drive for ripping into PC....
Posted on: 07 March 2013 by charnik
I also use a samsung slim portable  dvd/cd drive (SE-S084C) with PC for about 2 years without any problem. Maybe i am lucky or maybe samsung drives are reliable.
chamik,
Yes that's the same model that I have and it's excellent. I even dropped it once (ouch!) but it has continued to work perfectly.
Peter
Posted on: 22 March 2013 by jfritzen
Based on the suggestions I've got a Samsung drive now (SE-218). Apart from the first CD I tried, which happened to be defective, it rips really fast (from 4x speed on the inner sectors to 20x on the outer ones). XLD could successfully use Accurate RIP with this drive.
The eject button on the Apple keyboard does not work (works only with internal drives). The "silver" case is in fact grey and does not match the Mac Mini. Pregap detection takes some time with XLD.
I think it's a good drive for ripping.
