tagging wav
Posted by: aysil on 08 March 2013
Like the Naim Servers, other ripping devices which use wav as their "ripping format" create separate database files instead of directly tagging the wav files. Usually, it is mentioned that "wav format does not carry standardized tag support".
However, I know that some members tag their wav files successfully. Simon was even claiming that tagging was part of the specifications of the wav format in this post.
I will soon begin tagging my wav files. I want to ask those members who are tagging their wav files, if those tags remain readable across different servers or players. Can you tell me if common media players, for example iTunes, pick up these tags?
