What is your favourite coffee and how do you brew it?
Posted by: Richard Lord on 12 March 2013
I have several options, including Nespresso.  But I have recently re-discovered the art of percolating the coffee. Still experimenting with grain size and brands.
What's your preference?
Richard
Posted on: 12 March 2013 by count.d
Nespresso, bit hard to beat tbh.
Posted on: 12 March 2013 by pcstockton
I like the Keurig with the "blank" carts so you can use good beans.
Any heirloom bean from anywhere is good if handpicked, small batches, and sometimes unwashed.
-patrick
Posted on: 12 March 2013 by Fabio 1
Vergnano coffe brewed with the following,twice a day.
untitled
Posted on: 12 March 2013 by Richard Lord
I always drink it black at home.  But I sometimes enjoy a latte macchiato at a local Café Nero.
I was pleasantly surprised by Lyons Italian roast coffee bags, the red box. Bought as an emergency standby and surprisingly tasty.
Richard
untitled
That looks interesting.  How does it work?  I suppose the water is forced up into the top chamber, then  I (again) suppose you take it off the heat and the water is sucked back into the lower chamber. Or is it something else?  Does it require filters?  I am not too keen on those, makes for too much work clearing up.
Richard
Posted on: 12 March 2013 by Noogle
Kenya AA beans, fresh-roasted at the local independent coffee shop, ground and brewed in a Melitta-type paper filter directly over my coffee cup.  The hot water should go in "no faster than a man can pee".
Posted on: 12 March 2013 by winkyincanada
untitled
Richard
Yep, the water in the bottom chamber boils, creating steam under pressure that then pushes the water up a tube and through the coffee which is held in a finely perforated basket in the top. The brewed coffee is collected in the top half and simply poured out. It is referred to as a stove-top espresso maker and is simple to use. It makes full-strength coffee that can be diluted a bit for taste, if you so desire. Doesn't require filters.
The cast alloy ones like shown here (although very inexpensive) tend to corrode a bit. Stainless steel ones are also available.
These are a good travel option. You can even take them hiking/camping as they work over a fuel stove just fine.
untitled
Richard
Richard,Winky got it all right.I don't add a thing to what he said.That's it.Oh,have a nice coffee.
untitled
Richard
Winky,thanks for helping with the English:fantastic.
untitled
Richard
Thanks to both Winky and Fabio.  I will investigate this.  I think I saw something very similar in the John Lewis Store.  So, tomorrow will be a shopping day, yippee  .
Richard
I have ordered one, the stainless steel version, needed because I have an induction hob.
I have bought the 6 cup version after reading that is only just enough for a couple of normal sized cups.  This is it:
http://www.amazon.co.uk/Bialet...presso/dp/B0009Q1DSS
So thank you, Fabio and Winky.
I must be entering my second childhood to be so excited about a new coffee maker, but hey, who cares?
Richard
Posted on: 12 March 2013 by GraemeH
Excuse the 'Frasier' moment but for us Nespresso 'Indria' and others. It's the favourite for both latte & espresso.  Such a great product and the coffee machines operate at the right pressure to give a proper 'crema'.
Latte at 7:00am and Espresso at 5:00.......oh, it's 6:55....time to fire up the machine! G
Posted on: 13 March 2013 by mista h
Not to fussed what coffee i have as long as their is a little splash in it. Going thru a bottle of Brandy at the moment. Other half uses one of these fancy coffee making things and adds cream.
Mista h
Posted on: 13 March 2013 by tonym
Like count d. & Graeme I'm an Espresso guy. Having messed around with the alternatives it's so easy, clean and makes a super cup of coffee.
Posted on: 13 March 2013 by madasafish
Aldi's rich roast 100% arabica - in a cafetière.
I've tried machines etc. and it's such a faff.
Posted on: 13 March 2013 by winkyincanada
Richard
Just one word of warning. They actually almost "boil dry" at the end of the process and you must take it off the heat right away. They make quite a racket as they do so, but DO NOT leave the room while you're using it or you might end up wrecking it.
But they do make good coffee.
Posted on: 13 March 2013 by Richard Lord
Richard
Sounds like they should come with a health warning  .
Posted on: 13 March 2013 by NickSeattle
We like our Gaggia Titanium, and we have a Keurig at the other place we like too. Both are surprisingly good.  Nespresso is impressive, but we do not own one.  (The new Verismo pod-espresso machine at SBUX is styled like Naim  --  I am conditioned to smile when I see one.)
She prefers SBUX espresso beans.  I like variety more than any one type of bean.  Costa Rican and Kona are standouts.  But I usually go along with Her.
Nick
Posted on: 13 March 2013 by Julian H
My staple is Algerian Special, from the Algerian Coffee Store, Old Compton St, London, via my espresso machine. If I run out, Monsooned Malabar from Waitrose keeps me going. Getting the grind [burr grinder] right between batches takes a few shots but then its okay again for the rest of the bag.
Posted on: 13 March 2013 by Cbr600
untitled
Richard
Good choice Fabio, these are great ( and simple) machines that make lovely coffee.
Only problem is they come in a variety of sizes, 1 cup - 6 cup, and theyl become addictive so you buy a few sizes but they are relatively cheap
Paul
Posted on: 13 March 2013 by Fabio 1
Richard
Richard,don't expect to get a nice coffe from your very first cup:as Naim gear it needs a burn-in period,say 10 cups?
Posted on: 13 March 2013 by Occean
Tend to use freshly burr ground Has Bean coffee -  mount on cup drip paper cone filter.
Mmmm! Actually I want one now!
http://www.youtube.com/watch?v...re=player_detailpage
Paul,do you understand now what coffee means to my fellow-countrymen?
Posted on: 13 March 2013 by JRHardee
I use a Technivorm Moccamaster. It's pricey, but it's the only drip machine I've found that makes coffee as good as French press, but without the silt.
