I would like to buy a source with al the control of the n-Stream app. And also the volume control in it. I had a superuniti and that had it all. Now i'm looking for a solution like the superuniti but with my pass labs set up.
I don't have the qute jet.
Will the DAC in the qute have the potential to get the best out internet radio/TV/NAS/apple TV3 ( all digital connected off course )
So when i put the volume knob on about 11:00 on my pass labs pre amp, i select the input where the qute is connected. Then i can control everything with the n-Stream app. Also the volume??
Or will there be a better solution as i know as far with the qute. Does the ND5xs of NDX has a volume control in it? Or other equipment??
Hi Robbert
I think I can answer your first couple of questions.
You can use the Qute as a source - in the set-up menus you just need to set Speakers to None. The nStream app will control the Qute's volume.
Give it a try to see what it sounds like.
Gavin
