Unitiqute into a nap200/250
Posted by: thechain on 20 March 2013
Has anyone tried this?
I am currently running MacMini (old gen) - Rega DAC - Nait5i (c.2004) - B&W CM5.
Would a 2nd hand qute be a good way to go to replace the mac and rega? Would certainly be neater! Then take the qute through the 5i for now then pickup a 2nd hand nap250?
Posted on: 20 March 2013 by pjl2
Forgive me if I have misunderstood your question somehow but it puzzles me! The UQ is a one-box combined streamer/amp and is designed to stream music from either internet radio or hard disc via a local network. Your MAC/DAC arrangement is a different cup of tea completely, in that I presume your music is stored on the MAC and played via something like iTunes into the Rega DAC then to the Nait. IMO this is a far better and simpler arrangement as it negates the need for network streaming and the attendant problems. Not sure why you would want to use the Nait with the UQ, which already has on-board amplification.
Your best option would be to investigate the DACV1 to see if it improves on the Rega DAC, and possibly also the NAP 100 in place of the Nait.
Peter
Posted on: 20 March 2013 by MangoMonkey
I think I know what you're trying to do. I would probably stick to a 200 instead of going to the 250 as per Naim's recommended upgrade path...
Posted on: 20 March 2013 by Gurux
The golden rule is source first, preamplifier second, amplifier last (unless you have some seriously demanding speakers).
While UnitiQute is...cute , it is not the sort of source to make the most of a  NAP250 or even a 200.You want to go down this road, you will need all the bells and whistles - streamer, preamp, amp (or at least the streaming preamp for a start) and as many power supplies as you can afford.
Otherwise a UnitiQute feeding a NAP250 will sound fundamentally the same, think a UnitiQute on steroids.
Dan
Posted on: 20 March 2013 by DIL
Dan
Doing just this and agree with the comments made. The Qute is clearly the limiting factor as far as SQ is concerned...
/dl
Posted on: 21 March 2013 by Gavin B
Remeber that you'd still need something to fed the Qute i.e. your mac.
Posted on: 21 March 2013 by DomTomLondon
I've tried running a NAP100 with my unitiQute and it does make a difference to the sound. It's much fuller, the lows are improved greatly. Soundstage is also wider. And it doesn't struggle to drive the speakers. Just waiting on some extra funds and I'll be getting the NAP. Mind you, I've not compared it to higher-end Naim streamers.
Posted on: 21 March 2013 by Phil Harris
Demo'd this a few times last weekend at the Acoustica event up in Hoole with a Qute, a NAP100 and a set of S400's and the difference is not at all subtle - it really is a good pairing!
Phil
Posted on: 21 March 2013 by naimUnT
Phil Wouldn't a Uniti 2 be better value or even a second hand Uniti 1 (which comes with a CD as well)? One box instead of two and more or equal power than Qute + NAP100?
Posted on: 21 March 2013 by Gurux
Phil
Yes but there is a very simple explanation for it: the speakers need more power than the Qute can deliver. A pair of Neat Iota's would be a different story.
Posted on: 21 March 2013 by Barry Edgar
I recently added a NAP 100 to my Qute and run this with Neat Iotas. Like DomTom I have found that the sound from the system is much fuller.
Posted on: 21 March 2013 by Jan-Erik Nordoen
I hooked up my UnitiLite to an olive 250 to compare with the 82/HiCap, and got more articulate bass. The rest wasn't too shabby either.
Jan
Posted on: 22 March 2013 by pjl2
This combining of one-box systems with other boxes, such as external power amps, is something that never ceases to puzzle me. Yes of course the chances are highly likely that using an external stand-alone Naim power amp will enhance performance. The point of these systems though is that they are one-box systems.
As soon as you add something like an external power supply or power amp then to my mind you have completely negated the whole design concept in one fell swoop. If you want a multi-box system for performance reasons then a one-box system is not the most sensible starting point.
Peter
Posted on: 22 March 2013 by jobseeker
I say, can you tell me the way to Audio Nirvana ? Ah well sir, I wouldn't be starting from here
Posted on: 22 March 2013 by thechain
Thanks for all of your input. It has confirmed my initial thoughts.
I think the next logical step for me is to just upgrade the Nait5i to an XS and get a FCXS to partner it.
Either that or just go all the way and get a SN? Is the DAC is a SN better than my Rega one?
Posted on: 22 March 2013 by Gurux
If you don't mind piling up boxes an XS and DAC would be even better. The SN DAC is good  but the standalone DAC is much better and the price makes it a bit of a bargain (some people here prefer it to the NDS!).
And what price should I be looking to pay s/h for one?
Do you think that will make more of a difference in my system than upgrading the amp?
Posted on: 22 March 2013 by Richard Dane
No amp can improve your source, indeed, a better amp can often make things worse by revealing more limitations in a weaker source.
Second-hand Naim DACs start around £1,500.
Posted on: 22 March 2013 by Cbr600
Richard, i know this is a Naim site, and best efforts to keep the value of Naim up, but i disagree on the cost of used DAC
recent sales have shown the following
2008 - £1100
2009 - £1200
2011 - £1300
based on actual sales IME
hope this does not breach forum rules
No, that's fine.  I won't argue semantics - just an indicative figure going by the last few I saw.  I'm sure there may be cheaper ones and likewise more expensive ones depending on age, condition, private sale, auction, dealer sale, guarantee etc..
Posted on: 22 March 2013 by DomTomLondon
Peter
I take your point Peter. I also think that adding extra boxes to an all in one kind of defeats the purpose and look of the device. However some of us can't afford thousand pound multi box solutions from Naim. I managed to save (for quite a  while) to get an ex-demo unitiQute and a pair of KEF R100s. I'm happy with them, but eventually I'd like to add the Nap100 because I've heard what it can do. I think the Qute+nap100 will still be quite a nice clean little backage.
If I had the funds and space for a big setup I'd probably go for a Uniti2.
Dom,
Yes I think the UQ will look fine with the NAP100 and still be very neat and compact.
Speaking purely for myself, I dislike the idea of making something redundant (ie. the UQ's power amp) by adding a box that is not required at all. I know that if I owned one then it would stay as it was designed to be used - a neat little one-box set that whilst it may not match some of the abilities of some of the pre/powers nevertheless has its own special charms. If it struggled with the speakers then TBH I would rather get different speakers.........
Only my own very personal view and by no means one that should apply to everyone. Best of luck with getting the NAP100.
Peter
Posted on: 22 March 2013 by Brilliant
Luckily I build my own speakers. I use very high quality components and  can assure you that the Qute is worthy of very high quality transducers. When fed  a quality digital signal, it is capable of resolving the subtlest 'shades of sound', which many speaker designs do not.
It is worth it to lug it around and to try it with different high res speakers, as high as you can afford IMO. 30 watts into 8 ohms tells me that it has a robust output stage and  plenty of 'Naim  juice' so to speak. It will surprise.
Maybe you should try a SuperUniti then for the next level of "subtlest" or better still, separates . The main appeal of a Qute is size. Size and price. It's a versatile, accomplished product that can provide decent sound in a small place like a bedroom, maybe as part of a multi-room Naim system, built around, say, a UnitiServe.
I would certainly not build my main system around a Qute but I am actually thinking about getting one for my bedroom, with some Iota's and my soon to be delivered (4 weeks ) UnitiServe.
The main appeal of a Qute is the price as far as I'm concerned, for the quality and flexibility. I can easily see how someone could start there and build on when they get the funds. I have even seen people write that they prefer the sound of the Qute to the SU. The size is a bonus really. It's still worth buying if you end up using it only as a source (as I may do in due course, as the form-factor is useful). Alternatively, it seems to return good value for resale if you want to move up the range.
I'm not so sure about the price. A new Quite is 1400, I sold my one year old SNait, under warranty, in brand new condition, for 1800. For 400£, if your only priority is sound quality, I know what I would choose.
And I know people who prefer the DAC to NDS or the NAP300 to NAP500. This doesn't prove anything.
