how to set up mac mini with unitiqute?
Posted by: KenRose on 06 April 2013
Hi everyone,
I'm a 30 year Naim user who is now pretty frustrated and unsure of how to convert to digital. My longtime Naim dealer closed down, a pretty bad split, after 20 years he started defrauding customers including me. I mention this because I am without a dealer, and dealers in other cities are not super excited to help me because I didn't purchase my unitiqute from them.
I sold my previous Naim gear with the exception of my Credos and bought a unitiqute with the upgraded boards and software to play hi def files. I am also a mac user.... I have been streaming my music through my macbook air using eye connect and am VERY tired of the dropouts and the number of times my UQ cannot find the server. I wish to buy a mac mini and move my iTunes directly to the mini and hardware it to the UQ and go from there. Not sure how to do this. Any suggestions would be very much appreciated.
Ken
PS I have started to rip the CD's to iTunes using Apple Lossless.
Hi Ken,
the MacMini is a very good investment and perfect to maintain, handle and play your library. Your current albums can easily be transferred from you MacPro onto the MacMini.
probably the best and most reliable connection between UnitQute and MacMini is a digital SpDif cable. Many here use a cable Wireworld SuperNova 6 which brings superb quality (various threads here). This cable uses the digital mini jacket from the MacMini on one side, and of course the Tosslink optical in on the Qute.
does this answer your question ?
iver
Hi Ken,
iver
Ken - if you're going to keep streaming then get a wired network if possible to connect your UQ to your router.It'll save you a lot of problems in the future. Secondly ditch eyeconnect. It's rubbish. As you use iTunes try Playback as a UPnP server. It integrates with your iTunes library and will work perfectly with nStream and the Naim network players. Plenty of advice available on the forum to help you get sorted.
James
Agree with James above. I have a Mac Mini connected to a SuperUniti. It is connected via a HiFace SpDif converter (jittery slot loading mac) and wired via a switch to my router. For Upnp I use PlayBack and it has been very reliable.
The direct connection to the SU allows me to play Spotify and other things directly from the Mini and iTunes (ALAC) on the very rare occasion that there is a problem witthey ISP. A wired Upnp connection is essential for any HiRes stuff that you want to play. Depending on the size of your library you might consider an external HD (I use a G-Drive Mini) to store the music on. I replaced the internal 320 Gb with a 60 Gb SSD which is plenty to just handle the OS - very easy to do this yourself.
Good luck on your digital quest.
Neil
Hi Ken,
iver
Dear Ken,
You can use iTunes itself to play the music. To make life a bit more comfortable, iPad/iPhone users install the free app Remote on it. It will allow you to sit in your chair, scroll through your entire collection and control your playing. Apart from what tablet to choose, my personal experience is that a thing like a tablet opens a complete new era of music experience. You can scroll and "dive" anywhere in your collection, while being comfortably listening.
There is some software that helps boosting the performance of iTunes even more. Definately install/buy BitPerfect on the new MacMini. It is a few Euro's and automates sample rate settings for you. If you search the threads on this forum on BitPerfect, you'd find many positive experiences. More expensive is Audirvana. That might be for a later occasion, just get the MacMini running.
The moment you have bought your music, of course you have to transfer the MacBook Pro albums onto your MacMini. This is probably an easy copy-exercise, thoug I don not knwo how much music you have. In case of doubt/trouble, have a look at the website iLounge and look for the help section. Plenty of well-summarized guides for everything related to iTunes.
Lots of guys over here use the MacMini as streamer. However they store the actual data on a separate harddisk or even NAS (Network Attached Storage = like an external harddisk that is connected to your network). This is very handy since you might bounce into a capacity problem on the MacMini. Again, tons of info here on the forum on which drive or NAS to buy. Good news is, that you do not have to buy anything in the beginning: just start with your MacMini. You can add a NAS at any moment later on.
Good luck,
Iver
Hi Ken,
iver
Dear Ken,
Good luck,
Iver
James
Neil
Hi Ken
Ad. 1 it is an app for iPhone, Ipod or iPad. It is free of charge. Very good interface!
Ad. 2 no, it affects all music in itunes
Ad. 3 good choice. Try to get 8gb of Ram in the MacMini
enjoy the weekend,
iver
Hi Ken
enjoy the weekend,
iver
Hey Ken,
You indeed hardly "notice" BitPerfect is activated, but there should be an additional menu in your iTunes main menu. It has some options fro preferences for BitPerfect etc. ANyway: here is the manual: http://bitperfectsound.blogspot.be/p/manual.html
Iver
Hi Ken,
iver
James
I have a mac mini and uitiqute. I have a high quality toslink cable
http://www.lifatec.com/toslink2.html) and am also connected connected directly via the router.
having used the JRiver Media Center for Mac (I abhor i-tunes and use flac) I then experimented with upnp. No contest imho
upnp direct is an improvement on the optical out of the mac. The mac is system limited to 96k so if you use hi-res then upnp is essential.
So, I started with foobar Server from my PC (wifi to the router, CAT 7 wire to the UQ), realising that this is the way to go, I then tried to see what would give me easiest upnp access to the mac.
I had already setup my mac to work with my squeezebox touch (bedroom - wifi) using Logitech Media Server for Mac and N-stream simply taps into that - presto - done
N-Stream works a charm (iOS preferable to OSX version - the iOS version won't work if the OSX version is active) with the Logitech server on both wav and flac.
So, short answer:
Router (Cisco E900), with CAT7 cables between both the Mac and the UQ, Logitec Media Server for Mac, iOS N-Stream controller
