Super Uniti with Airplay?
Posted by: Yeast on 12 April 2013
Can someone tell me how I determine if my Super Uniti has Airplay installed?
Posted on: 12 April 2013 by RaceTripper
None of the Naim devices -- including your SU -- have AirPlay at all.
You can add AirPlay very easily by using an Airport Express and connecting it's optical output to your SU. An AppleTV will also work, but I believe it converts 44.1Khz audio to 48Khz, which is less desirable.
Posted on: 13 April 2013 by robert-
Yeast, did you not know this when buying this top end item?
Posted on: 13 April 2013 by Yeast
I didn't know about airplay when I bought it, but it isn't a problem for me since I use my ATT network. I am selling my SU so I needed to find out for a prospective Buyer. Taxman has hit me hard. I'll have to survive a while using my Unitiserve with my Sonos system into a Cary SACD/DAC.  It sounds good enough, but limited to 24/96K.
