HDX and SACD
Posted by: PeterX on 17 April 2013
Have just ripped a SACD disc to my HDX. All normal information such as tracks etc etc seem to have downloaded but it will not play!
Is this a known problem or fault?
Peter
Posted on: 17 April 2013 by Cbr600
Peter, not aware of any issues here
I have a number of SACD discs ripped o my HDX and no issue at all
In my case the HDX ripped to the NAS which is se up as the primary source, but dont think this shoud be of any relevance
Posted on: 17 April 2013 by Manu
Check your Ripping history log in Destop Client, this disk may not have been ripped correctly, you may find errors...
If it is the case, erase it from the HDX, and retry to rip it.
You may copy it on a CDR and rip that CDR...
Some SACD' cd layers are really tough to read.
Posted on: 17 April 2013 by Harry
Two recent AF releases have been impossible for our HDX to rip but dBpoweramp and my PC drive found the CD layer just fine. I then sent them across the network to the NAS.
Posted on: 17 April 2013 by PeterX
Thanks all for replies. Unfortunately I don't have any other means of ripping so guess I will have to put up with not being able to rip this particular album to the HDx. Interestingly I happen to to look at the ripping monitor via my iPad when ripping and it did look as though it was ripping each track successfully.
Peter
Posted on: 20 April 2013 by sktn77a
I'm not aware that the HDX supports SACD.  However, if it appears to be ripping something to your HDX hard drive, can you see the ripped files from your computer (either through the DTC or Windows Network view)?  If you can see it, can you play it on your computer through the network view?
