Are all NAS equal?
Posted by: stpierre76 on 11 May 2013
Hi all,
I ve decided to use the qute as it was I tended to be, as a streamer, thanks to many of you that have steered me into that direction ( thanks you indeed).
I went out a bought 2 iPad mini so that I could use the n stream app ( there s less than $60 difference between an iPod touch and mini, plus my eyes will thank me for the bigger display
Now I will need to buy a NAS in order to load all my music collection into it and be able to access it from the qute via n-stream and nit have it store into my laptop and have it running 24/7.
So, Are all NAS equal? Are they any better ones out there, any better one that work best with naim. Hopefully, I need one that is easy to configure out of the box and use as not very computer savvy.
I will probably need a minimum of a single 1Tb and better 2 x1Tb.
I ve never had a NAS and always been reluctant to get one as a bit afraid of the set up, but this time m going forward.
Is a NAS a simple solution for naim streamers. Just load it up with music files, connect it to your network and the naim streamer / n-stream, automatically finds it and you can start playing tunes?
Any recommendations and advice will be greatly appreciated.
Froggy
