ITunes 11 Help
Posted by: RobH on 22 May 2013
I have made the mistake of loading ITunes 11, help.  I'm not sure if I'm an idiot (my wife assures me that I am).  System remnote hard disc, MacMini, ITunes, BitPerfect, NDac operated headless using an IPad via remote.
Problems a) I can no longer play whole albums even if I hit the play all button, b) if I go to play as I used to via the album cover I get about 5 seconds of play.
Basically I can no longer play music.  I have downloaded ITunes 11 twice in case it was corrupted the first time, still no joy.
Should I move away from ITunes and if so to what?
HELP
Posted on: 22 May 2013 by Adam Meredith
I, too, thought I was being thick.
Itunes only seems to want to play 'ticked' songs.
Go into song view - edit/select all - right click - tick selection. Illustration has 'untick selection' - as they are presently ticked.
Posted on: 22 May 2013 by RobH
Adam thanks, that sorts one problem out.  However the darned thing plays for a couple of seconds then stops, if I hit the play button again it plays fine.  This happens at the start of each track.  Mighty tedious.
Rob
Posted on: 23 May 2013 by tonym
Hello Rob,
this is a known issue with the latest version of iTunes. I don't currently use BitPerfect but I understand the very helpful chap who developed it has come up with a fix, so you should be able to download this from the BitPerfect website.
Posted on: 23 May 2013 by RobH
Tony, thanks for the reply, I have email BitPerfect.  You are right he really is a very helpful chap with, what I think, is a great product.
Rob
