When things go wrong, check the simple things first . . .
Posted by: Bart on 27 May 2013
As much as I love this technology, when things go wrong I often have too-little patience.
Today I had to reset my home router (I seem to have forgotten the password), which involved pulling stuff off the rack and pushing a paper clip into the reset button.
Whereupon, the UnitiServe would NOT get on the home network. Rebooted the router and the uServe each a number of times. Everything else was on the network BUT the uServe. Had dinner . . . . some wine . . . tried again . . . nothing.
Finally discovered that the cat5 cable had some slightly dislodged from the switch. Looking at the switch I did find it odd that there was no green light over that one port, which gave me the clue; the green light came on upon removing and reinserting the cable. I must have pulled the cable loose when moving stuff around on the rack in the course of resettting the router.
Although there are all sorts of software settings in routers, etc etc that MIGHT be a problem, there is nothing like a poor physical connection to stop it all. After I could not think of any software problem that it might be, I resorted to the physical connections and found the problem pretty quickly.
I really do get frustrated when this stuff doesn't work right! And often it's the simple stuff ![]()
