vinyl vs cd
Posted by: meni48 on 14 June 2013
i have a question,what is a better sound file to download in your opinion a vinyl file or a regular cd file into a flac format through the internet
I don't think anyone sells ripped vinyl files. So any ripped vinyl file will be a pirate file...
Actually Richard there is a commercial example of this. If you purchase the Nick Drake boxed set of the re-release of Pink Moon, one of the downloads included (along with standard and hi-resolution digital files) is the ability to download a recording of the original Nick Drake Pink Moon LP as played on the family stereo system. So, essentially a digital download of an LP rip. It is more a curiosity than anything and certainly not near the sound quality of the remastered LP or the other resolution digital files, but is a very good "ripping" of an LP.
Yes, I forgot about that. But it seems the exception, and not one that undermines the rule here...
It's legal to buy a ripped vinyl file as long as you also buy the vinyl. IE.You buy an LP and the seller also supplies a ripped file of that record on CDR.
http://www.musicstack.com/list...hs&media=vinyllp
Top of the page shows sellers supplying LP only, scroll to bottom for suppliers selling LP + CDR.
As to which is better, it probably depends on quality of front end rather than the type of media.
Doesn't it still turn into digital bits whether it's from vinyl or tape? it turns into 1 + 0s.
Vinyl still has its smooth wavelength instead of etched steps no matter how many bits it is turned into. Apples and oranges
I think "no," because by that logic all trumpets and cellos and glockenspiel only produce an analog waveform . . . You see where I'm going.
I've yet to find any vinyl rips compelling, but certainly have only listened to a few.
Hi MudWolf
only recently I read about how anolog recordings aren't 'continuous' either and why it is that analog recording devices have a limited bandwidth.
Very enlightening: http://www.pstracks.com/pauls-...isconceptions/10705/
Aleg
Hi MudWolf
Aleg
Don't know about enlightening, seems a bit far fetched. Where does this starting and stopping theory come from.
