Unitiserve Disk Temperature
Posted by: T38.45 on 21 June 2013
Hi Folks,
just checked my US system status- the disk has 56 C.
The fan is not running, so is this ok?
Ralf
Posted on: 21 June 2013 by True Blue
NO its about to blow up!!!
Seriously why does anyone need to know the disk temperature?  Just let the fan do its work when its programmed to.  If it doesn't then it will be covered under warrenty.
Posted on: 21 June 2013 by rjstaines
These do run hot. Mines at 50 degrees and has been for a couple of years.
As TrueBlue was saying in his own inimitable way... don't worry !
Posted on: 21 June 2013 by T38.45
Thanks!
Posted on: 22 June 2013 by garyi
Before swapping to an ssd my imacs hhd would frequently hit 60 plus degrees.
