Uniti 2 input level
Posted by: demaps on 25 June 2013
Hello all. New here so any advice much appreciated.
While setting up ipad via airport express to Uniti 2, I noted that the input level on the Uniti was set at a rigid 72. A moment later I hit the mute button as airport express suddenly configured, almost streaming my new speakers into darkness. So I minimized the ipad output level to compensate, halved the Max output volume on the Uniti.. Streaming / iTunes is all sounding pretty good but I wonder,
I am concerned going forward that an oversight by myself or sig other may blow a speaker cone or two.
Cheers in advance,
Davy
Posted on: 26 June 2013 by jobseeker
Have you checked the set up menu to see if the input has been assigned a fixed volume level or input boost (assuming that's possible) ?
Posted on: 26 June 2013 by demaps
Just checked, and yes, input had been assigned a fixed volume. So an easy solution there. I wondered why the I could only adjust volume from the ipad. Seems I bypassed the obvious fix and tweaked everything else. Thanks. Short thread this one..
