WD MyBook Live Access to Streaming Folder?
Posted by: GraemeH on 28 June 2013
I've been using my NAS as HDX back-up only to date but I'm getting near capacity on the HDX. Can I create a new 'Share' then copy all my back up files over to it on the same NAS - and then access that from the HDX to stream?
Or do I need a separate NAS? One for back-up and one to hold files for streaming?
Many thanks,
Posted on: 28 June 2013 by Paul Quigley ie
will need 2 NAS. One to use and one as a backup.
I have two Nas boxes broken right now!
Paul
Posted on: 29 June 2013 by GraemeH
Thanks. G
Posted on: 29 June 2013 by GerryMcg
Graeme,
 The "second NAS" could be an external hard drive which will be cheaper. Preferably with USB 3.0 for speed.
Gerry
Originally Posted by GerryMcg:
Graeme,
Gerry
Attached to the PC or straight to the HDX Gerry? (I know naim don't recommend the latter but some seem to do it) G
I attach the external drive to the NAS, the latter is programmed to back up to a schedule.
Gerry
Thanks. G
