Coaxial v Optical
Posted by: The Meerkat on 04 July 2013
I appreciate that this topic has been aired many times before, sorry folks! However, I have just got a new nDAC which is fed with music from my Unitiserve, using a £150 Mark Grant, pure silver Coaxial interconnect. The nDAC Is then connected to my Supernait using Naim's Din cable...I then tried a cheap old optical cable that has been stuffed in a draw for ages, and connected the nDAC to the UnitiServe with the optical cable.
I really could not hear any difference! But, I should have though, shouldn't I?!! Perhaps I need to get my hearing checked out!
Good quality cables do make a difference, but in my case at the moment it hasn't worked?
I obviously want to pull the best from my new nDAC, should I get a more expensive optical and dump the coaxial?
