Does an audiophile rack optimise SuperUniti?
Posted by: AndyL on 13 July 2013
Hi everyone
I have my SU on the lower shelf of a large mahogany end table - nothing else on the shelf - very rigid but not what I'd call light
Tried sorbothane pads under the SU, think it sounds tighter without them
Generally very pleased with the sound
Rest of kit: Totem Arros via NACA5 plus Powerline
Am I likely to improve the sound using a dedicated audiophile grade rack e.g. Fraim?
Would dem of course
Andy
Posted on: 13 July 2013 by hungryhalibut
I've not tried it on Fraim, but I got a big improvement switching from the heavy Hifi Racks Slimline to the very light Quadraspire Q4 Evo, so I imagine Fraim would be better still.
Posted on: 13 July 2013 by engjoo
I believe the fundamentals behind these are the material's ability to absorb and transmit vibrations around itself so the choice it materials and its structure is key towards a good support.
Posted on: 17 July 2013 by rupert
Hi andy do think pl really works on su regards
Posted on: 17 July 2013 by hungryhalibut
I was very dubious of the merits of the Powerline, but now use on on my SuperUniti to excellent effect. And with a SU, you only need a single Powerline to optimise the whole system!
Posted on: 18 July 2013 by AndyL
Yes I've tried with and without; for me it makes quite a difference in tighter bass and clarity
