Streamer not responding
Posted by: Duffryn on 14 July 2013
My Uniti needs switching on and off every time I use it. It's up to date as is the NStream app. The message I get is Streamer Not Responding and then it can't be found on the network unless re-booted.
Does anyone have experience of this, I would love to know how to cure it.
Any help will be greatly appreciated.
Posted on: 26 January 2014 by garyi
Give some details of your network, router etc
Posted on: 26 January 2014 by hungryhalibut
As the question was raised over six months ago, it may now be resolved......
Posted on: 26 January 2014 by Mrs Wogan's lemon drizzle cake
Hi there, did you any get anywhere with this issue?  i'm having the same problem.
cheers,
Matt
I'm connecting the uniti wirelessly via a virgin super hub. Basically the uniti drops off the network seemingly randomly.  After which i can no longer ping it from any other devices on the network, and i can no longer access my NAS or internet radio.
All other devices on the network are still connected fine.  I've tried both DHCP and static IP and also a factory reset.  The dropout usually manifest itself as i'm listening to internet radio, and i get a "streamer not responding" message.  Also the factory settings menu shows network status as not ready. a reset of the uniti usually does the trick, after the network is reinitialized every things fine again.
The uniti is using firmware 3.0.0 - is this an issue that has been fixed in pervious versions?
So it was! It was on the front page of this forum this morning, I do wonder about this forum software.
