Would iSupply be an upgrade for nServe?
Posted by: Jonas Olofsson on 15 July 2013
I have an iSupply, basicly never used, laying around.
Would it be possible to use it (configurated) with a nServe and would it be an upgrade to the power unit supplied?
Not sure many if anybody could answer this but if Phil or some other expert would like to comment it would be appreciated.
//Jonas
Posted on: 15 July 2013 by Bart
Jonas, the official answer you'll get is that Naim do not support modifications to their products, or the discussions of such modifications, here on the forum.
I assume that you mean the uServe.  Have you looked to see if the dc outputs are the same for both devices?
Posted on: 15 July 2013 by Jan-Erik Nordoen
As Bart indicates, the DC output of the iSupply is 24 V, whereas the UnitiServe requires 12 V at 4A. The iSupply is specific to the Headline and Stageline.
Jan
