n-stream volume control NAC202 - ND5XS
Posted by: andelun on 18 July 2013
I couldn't get the volume control buttons on n-stream get to work. Thanks to help from Steven Hopkins (NAIM support) I managed. As there was no information on the Forum about how to do it I'll post the solution.
On the back of your NAC202 is an RCA socket labelled RC5 in. On the back of your ND5XS is a 3.5 jack socket labelled Remote in. Y
ou need a mono 3.5 jack to single RCA phono lead to go from the RCA socket to Remote in on the ND5XS. If you have a stereo 3.5 jack then use the red RCA plug.
Then follow instructions in the ND5XS manual page 15.
- The System Automation setup menu comprises five items.
- Select Preamp and chose Enabled.
- Select Streamer Audio and chose Input Used - Pre AV.
