Digital Media?Music Management
Posted by: Woods Scot on 19 January 2011
As I can't seem to figure out how to search older posts, wondering if anyone can recommend a music management program. I am a Mac user and currently use itunes out of convenience. Just looking for something more, dare I say, more audiophile...?
Posted on: 19 January 2011 by james n
To do what ? I thought you had a Unitiserve ?
James
James
Posted on: 19 January 2011 by realhifi
Why use the iTunes interface when you have the Serve interface? Doesn't it compile all your files into one searchable database?
Posted on: 19 January 2011 by Woods Scot
I have a large number of digital files (ripped cd's), that I saved and are currently stored on my mac mini. I am not able to transfer these to my unitiserve; and I still want access to them (which I currently have through the unitiserve).
The problem with itunes is that the files are stored and album art is not recognizable through the nserve interface. I have to physically go through all my files and insert album art as "folder.jpeg", into each of the artist/album folders. This is a lot of work. Additionally, when the files are read from my mac/itunes folder, many of the songs are listed with track number beside them, and sometimes with "odd" characters "-_+ etc. Which again will require me to go through them individually and edit them.
I also have plans to download hi-res files from the net and need a place to store/compile them.
I guess I could rip the files to a cd and then to the nserve, but this becomes a bit redundant.
Scot
Scot
Scot - there are a number of scripts for iTunes to sort the album art out for you.
Try Image fetch
James
Try Image fetch
James
Thanks James. Hoping others have some insight as well.
Posted on: 19 January 2011 by garyi
Media rae can hep sort out art work, there are plenty of scripts and applciations that put art work into itunes.
For a more 'audiophile' experiences there is ayrewave for mac.
You could really go to town and waste 800 quid on ammara, plenty have done so you could be next.
How is Amarra going to do anything if the files are played via the Unitiserve. Come on Gary, if you are going to slag the product off (as you always have done) then at least try to understand what it does first ..
Posted on: 20 January 2011 by Ben G
Hi Scot,
IMO iTunes can't be bettered as a tool to manage your tagging, artwork, etc. especially on the Mac. An 'audiophile' solution only becomes relevant if you are using it to rip or to play music, which of course you are not, having the serve. The only down side is that it doesn't do FLAC, but you can convert any of these to ALAC and the Serve will be able to handle them from iTunes.
What you need is a way to automate the process of extracting the artwork and removing numbers, etc. from songs. As others have said, AppleScript is the way to do this. Google Doug's iTunes Scripts and have a browse. There are plenty on there which can remove track numbers and tidy up track names and tags in other ways. A quick search on there also reveals "Save Album Art To Album Folder 2.0" which seems to do what you want with the artwork.
Ben
Ben
Posted on: 20 January 2011 by Woods Scot
Thanks Ben,
I have installed them as directed on the site, but cannot figure out how they become active (ie haven't noticed any changes in my folders). Trying to figure things out, but am a bit stumped (bit of a novice at this sort of thing).
Thanks for the help, and if you can offer any further instruction, please do.
Scot
Scot
Posted on: 20 January 2011 by garyi
James, the guy said he uses itunes. I therefore made a leap. Seemed reasonable to me.
Hi Scot,
Once you have the scripts in the correct folder, open iTunes and along the bar at the top of your screen, together with File, Edit, View etc. you should see a little icon that looks like a scroll. The scripts are activated from there. Normally you first highlight the tracks you want to apply the script to (try a small number as a test first) then select the script to run on them from that menu.
Hope that helps.
Ben
Hope that helps.
Ben
Thanks Ben. I'll give it a try
