How do you quote previous replies?
Posted by: winkyincanada on 22 January 2011
I can't figure this out in the new format. Was very easy in the old one. Now obscure (to me, at least).
Posted on: 22 January 2011 by kuma
1. click on post reply ( or add reply on the upper right with a giant green plus sign which somehow I missed )
2. highlight the text you want to quote
3. press quote button in the input box
4. quote should appear if you are using the right browser. ( mac Firefox works, Safari, iPad, iPod do not ) NOTE: it does not say *quote*. Default is set up as *reference:*
It's a lot of work and doesn't work across all browser. Currently it's probably just as easy to just cut and paste and change colour of the quoted text.
Posted on: 23 January 2011 by winkyincanada
Testing quoting
Didn't work. I highlighted some text and clicked the "quote" button but nothing happened. I'm using IE with Windows 7. I also agree with others that having the reply box kind of stuck to to the page is a bit dumb.
Posted on: 25 January 2011 by dave simpson
Not working for me either using Kuma's instructions. Using Win7 Pro and IE 8 here.
Posted on: 25 January 2011 by roger poll
Reference:
Dave, do what I did and install Firefox. Solves the problem.
Posted on: 25 January 2011 by Chalshus
Dont work here. Safari 5.0.3 on OS X 10.5.8.
I have to type [quote][/quote] .
