The USB cable is it important?
Posted by: Wotan on 27 January 2011
I have read different opinions on the subject. Apparently, some DAC are more sensitive than others to the quality of the USB cable (correct me if I'm wrong). Currently I have a cheap USB cable to connect my mac mini to the EVO. I have two questions:
- Can any USB cable can handle files of any sample rate?
- Since I have a Naim DAC, does the usb cable is it important? In this case, what you advise me?
Thanks.
The choice of USB cable shouldn't matter and all should easily cope with any sample rates.
However, for peace of mind, you should be able to pick up a well made USB cable like AudioQuest Forest fairly inexpensively (£20-30). Anything costing more than this is probably a waste of money.
"USB cables make a demonstrable difference. For my tests with the Debussy, I experimented with five of them, ranging from the Brand X variety that comes with printers to audiophile affairs from Synergistics and Kimber. The winner this round—just as in the last time I conducted a USB cable survey—was the unpretentious Belkin Gold Series. The difference this cable makes is not remotely subtle. Depending on what you are comparing it to, it can be the difference between music and wallpaper. Here, blessedly, in one area of the high end that does not require spending a fortune; I picked up my 6-foot set at Amazon for $4.88."
-- Daniel
For me it is the other way around; the better your DAC the less it should be intluenced by differences in competent cables. If I had a DAC which was influenced by cables, I'd be looking for another DAC, not another cable!
If a device isn't able or capable to show the effects of difference in inputsignals than it is a great equalizer, which makes everything sound the same and probably not very sensitive. That means to me, it will also not be very sensitive to display differences you do want to hear in input signals.
If USB cables sound different then why not ask the people who designed your DAC what USB cable they use? And why other cables sound different?
Or if you accept that USB cables degrade the signal, give up using USB !
Quite right. The USB cable galvanically links your DAC and components downstream (depending on design) with the computer its connected to which can give varying results. Get a decent cable for around £50 tops. Audioquest are good in that they take the trouble to improve the isolation of the power wires in the cable which prevents coupling of interference from the power wires coupling into the data lines and making its way downstream.
James
You'd hope so.
James
Turn your volume up to maximum (slowly) with nothing playing, but the USB input selected. Should be utterly silent. Or do the same with something very quiet playing. Poorly isolated DACs can make birdsong-ish warbling like noises. If you unplug the USB lead there should be no noises; if you unplug your laptop from it's power-supply there should be no noises. Even at full volume, but don't try at full volume first!
The Halide is a good quality cable that does considerably more than your average USB.
It is useful in all this to remember that USB was never designed to pamper audiophile ears; it has been adopted out of convenience as a way of liking traditional HiFi and the huge installed base of USB ported computers (significantly fewer have firewire!)
It would be a miracle if bog standard USB sounded as good as a wire someone had bothered to consider as a possible medium for transmitting timing sensitive data into someones precious dac.
The arguments about USB are still raging over on Computer Audiophile (seems like years) and the guys are probably having a whale of a time. Great if you like to watch paint dry.
Buy a reasonably good cable that is proportional to the amount you spend on your kit.
Then concentrate on listening to the music.
Tog
quote:I would like to hear from Naim their opinion about this. Naim DAC is sensitive to different usb cables?
You cannot connect your EVO or any other devices (except USBstick) to the nDAC with a USB-cable, so what is the point?
aleg
IIn any case, I wonder what kind of usb cables used Naim for their test.
The Naim DAC it not directly influenced by any cabling connected to the EVO.
I wouldn't expect Naim to do any testing with EVO-like devices but only with devices that use optical or COAXial cables. And than only probably its own devices and not from third parties.
aleg
I understand that with this answer I should already have enough, but I just wanted to know the Naim's world opinion about this.
We have just taken delivery of the new Rega DAC and I have not yet had the opportunity to run through the cables again to see if we get similar results.
The best value for money (against the bundled cable) was the LaCie USB cable - very cheap by comparison to the Wireworld offerings. But the clear winner in terms of sound delivery were the wireworld products.
I care not for the "why it works" but have judged everything on merit of sound using fairly modest amps, speakers and analogue cables (Nait5i, 202/200, Totem Mites/allaes, Chord Company Cobra).
I would strongly suggest that it is worth trying a couple of alternatives and make your own judgement call on the results.
Worth noting that the USB specification turns off error detection when streaming audio & video content and the cables that we have experienced delivering superior results are a flat cable design.
