nDac Display
Posted by: Woods Scot on 28 January 2011
How does one turn off the display of the nDac or is it possible?
Scot
Scot
Posted on: 28 January 2011 by GerryMcg
Hi Scot,
If you contact Naim direct they can supply a copy of new firmware, that enables the display to be switched off. It is simple to install. Note that the Sync light will still illuminate if connected.
Gerry
Gerry
Posted on: 28 January 2011 by Woods Scot
Thanks gerry. Just received my nDac, and am setting things up with my nserve, etc. I will post my thoughts in the very near future. But so far, I am impressed.
Scot
Scot
Once its settled in try some HiRes downloads, they are might impressive through my Serve/nDac combo.
Gerry
Gerry
Posted on: 28 January 2011 by Scooot
hi scot,
if you have just bought the ndac you may well have the new firmware already installed.try holding down the pre button on a naim remote then pressing the display button.this worked for me.as gerry says the sync light stays on.regards scott
All sorted. Tried the DISPLAY (held) and then pressed the PRE, and voila ! I am looking forward to my venture into distributed audio.
Scot
Scot
Posted on: 28 January 2011 by Aleg
The proper order is to:
1. press the pre button only shortly to switch the remote to commands for the pre-amp & nDAC
2.a. press button Display shortly for turning off/on the display of the pre-amp
2.b. press button Display somewhat longer / press-and-hold to turn off/on the display of the nDAC
aleg
aleg
Thanks for the clarification Aleg.
Scot
Scot
