I've gone back to foobar2000!
Posted by: Hot Rats on 19 July 2013
I have an Acer laptop with i5 processor and 8GB RAM running Windows 8. I was using JRiver Media Center 18 with JPlay installed and the JRemote app to control the system from my iPad. I really wanted to try out the Hibernate mode in JPlay as many on the JPlay forum reported that it offered significant improvement. It has been proven that the JRiver Media Center/JPlay/JRemote combination does not work with Hibernate mode enabled. The foobar2000/JPlay/MonkeyMote combination was reported by some to work, enabling the user to retain remote control of the system with Hibernate mode enabled.
I installed the foobar2000/JPlay/MonkeyMote combination and tested it with Hibernate mode off. It worked fine but as soon as I enabled Hibernate mode I had problems. Playback could not move from one track to the next and the maximum amount of time that I could get a 16/44 rip to replay without hanging was about three minutes. I tried adjusting the foobar2000 buffer setting and the buffer settings in JPlay. I changed from Xtream, the default JPlay engine, to UltraStream but I just could not get it to work. I then installed the same combination on a much older ASUS computer with an Intel P6200 processor and only 2GB RAM. I thought that it could not possibly work but much to my surprise it did! It was back to the drawing board again. I disabled Windows Defender as recommended and that didn't help either.
On my old ASUS laptop, I installed Windows 8. It is a very minimal installation with no superfluous additional software. My new Acer computer came with Windows 8 pre-installed at the factory and while I had removed the unnecessary software that was also on the machine, the Windows installation itself contained a lot of associated Acer bloatware. very helpful for most users I'm sure but not for computer audiophile applications.
I had already made an image of the Acer laptop so that I could reset it to factory settings if required. I wiped the hard drive of the Acer and installed Windows 8 myself, opting for the most minimal feature set possible. I then installed the foobar2000/JPlay/MonkeyMote combination and this time it worked!
The people at JPlay are right in saying that Hibernate mode does offer a significant improvement. I have been listening to music all day, including HiRes material at 24/96 and 24/192. I also installed the SACD input plugin for foobar2000 and I can now listen to DSD files, converted to 176400 PCM on the fly.
It was worth the hassle trying to get my system to run in Hibernate mode while retain remote control from an iPad. I am informed that installing Windows 2012 Server will bring about another improvement in sound quality. Maybe I'll try it one day but for now, I am just going to enjoy the music!
