Synology NAS problems
Posted by: John Burrow on 21 July 2013
I use a synology disc station 410 and mostly found it to be flawless, however for the last month none of my streaming devices is finding any new files placed on it, the N stream, and DS audio apps along with an oppo Bluray and a samsung bluray are not showing audio or video files, a windows and an apple computer in the house have no trouble reading or writing to the NAS, the disc station is running latest software, I've even done a reset from the rear of the disc station. Both the N stream and DS audio are up to date. I'd appreciate any thought on this problem. Thanks.
Posted on: 21 July 2013 by garyi
Sounds like the DNLA/UPNP database has gone wrong, try forcing a rescan from the NAS browser (Or UPNP browser)
Posted on: 21 July 2013 by John Burrow
thank you garyi, I'll give it a try
Posted on: 21 July 2013 by TN
I have an older 211j and sometimes I have to copy the files once or twice before it shows up on N Stream.  When that happens, I find that when I log into the Synology and check via the Audio Station, the copied files do not show up there too.  Dont know why that happens but it does.
Posted on: 21 July 2013 by Doc
I have the same problem - files can be seen with windows explorer by not with Ipad
Clearing the cache on the IPAD normally solves the problem
Posted on: 22 July 2013 by latecomer
You mentioned ds audio is up to date, might want to check if Media Server is up to date too.
