MinimServer / Help Needed / Album vs AlbumArtist
Posted by: Lorenz on 28 July 2013
Hi there,
just started to "like" MinimServer.
Reliability is great but user interface is something I'm having my issued – especially when it gets into "scripting" or things/items/expressions MinimServer handles different from other UPNP servers.
Tried my luck the so called manual but fail to get a decent "AlbumArtist" item/tag/seletion. MinimServer's approach on this does not work for me...*
Would like to have something like
album PLUS albumartist BUT NO compilations
Possible? Can anyone throw me a line (ready for copy & paste) or lead directions to instructions that I could follow without taking NASA or NSA lesseons...?
Lorenz
* from the online manual:
Index tag selection
When MinimServer reads your audio files during startup, it reads and indexes the following tags by default:
 Artist, Date, Genre, Composer, Conductor, Orchestra
You can customize MinimServer to read and index a different set of tags by changing the tag names listed in the <code>indexTags</code> property and restarting MinimServer.
The Artist and AlbumArtist tags are indexed specially, as follows:
If you want to display an index tag with a different name than the tag name in the audio file, you can do this by suffixing the <code>indexTags</code> entry for the tag with a colon followed by the substitute name. For example, to read and index the Composer tag and display it as Komponist, you would use<code>Composer:Komponist</code> as the <code>indexTags</code> entry.
When browsing your library, the list of index tag choices is displayed in the same order that the index tags appear in the <code>indexTags</code> property.
Posted on: 30 July 2013 by Reinibert
Hello Lorenz,
minimserver is much easier as you think. Open the "Propperties" of the Minimwatch, if the server runs on a NAS or if it runs on your computer on the minimserve itself.
There are lines you can edit. For your wish you need to change the Line "indexTags". My entree in this is:
"Albumartist, Composer:Komponist, Composition:Komposition,Genre, Conductor: Dirigent, Orchestra: Orchester, Solist,#AudioData:Qualität, Date, Artist"
To have AlbumArtist in your shown list you only have to add it in the line "indexTags" and restart minimserver. If compilations ars shown under AlbumArtist or not depance on your tagging. If you leave for Compilations the AlbumArtist clear all compilation will be appear under "unknown" at the end of the Albumartist-list.
My entrie shows in Kinsky or nStream
Albumartist
Komponist
Komposition
Genre
Dirigent
Orchester
Solist
Qualität
Date
Artist
I hope I could help you.
Nearly the same in German because my English is not so good:
Hallo Lorenz,
der MinimServer ist einfacher als Du denkst.
Je nachdem wo der Server läuft kannst Du die Propperties auf dem MinimServe direkt oder im MinimWatch öffnen. Dort findest Du die Zeilen mit denen man den Server steuern kann. Unter indexTag trägst Du die Namen der Tags ein, die in den Steuerprogrammen wie Kinsky oder nStream angezeigt werden sollen. Meinen Eintrag habe ich oben ja schon kopiert. Dabei ändert der Eintrag Composer:Komponist den Anzeigenamen des Tags. Es wird also für composer Komponist angezeigt ohne die Tags der Flac-Dateien zu ändern. Ich hoffe, ich konnte mich verständlich genug ausdrücken.
Deinen Wunsch nach album PLUS albumartist PLUS NO compilation kann man dort aber nicht erreichen.
Erstens ist beim Aussuchen immer bei Album die Auswahlmöglichkeit zu Ende. Das heisst, danach hat man nur noch die Titel und keine Albumartist etc mehr.
Zweitens zeigt Dir Albumartist den Inhalt des Tags an. Wenn er lehr ist, werden diese Alben unter "unknown" geführt. Ich selber verwende dafür den Begriff "Sampler" und schreibe diesen in den Albumartist. Damit stehen diese dann unter "Sampler".
Wenn Du die Compilations bei Deiner Suche über Albumartist bewußt ausschließen möchtest gibt es aus meiner Sicht nur die Möglichkeit ein eigenes Verzeichnis Compilations parallel zu dem Verzeichnis zu erstellen, wo alle andere Musik gespeichert wird. Dann kann man beim Ausuchen zuerst Folder-View wählen und  dort das Verzeichnis Musik auswählen. Damit sind alle Compilation, da im anderen Ordner, nicht mehr berücksichtigt. Anschließend wieder auf Tag-View gehen. Dann hat man alle Alben ohne Compilations. Dann also auch unter Albums nur diese.
Ich hoffe das hilft Dir. Der MinimServer ist meiner Mainung nach derzeit der beste und variabelste UPNP-Server. Insbesondere für Klassik.
Lieben Gruß
Reinibert
