MacbookPro/Audirvana/Audiophilleo1 vs. Thumb drive!!!
Posted by: Naimthatune on 31 July 2013
Firstly, thanks to all those who take the time to help out on the forum!
My CDS2 died recently, and like so many I decided to explore streaming.
I managed to find a nDAC and hooked it up to the XPS and the above feed. I backed off several reference CDs in Lossless and AIF format to a NAS drive and connected my MacBook Pro direct via Ethernet.
Audirvana runs over iTunes and streams via the Audiophilleo device straight into the nDAC..
The sound is surprisingly close to the former CDS2, but when I copied the same music files to a spare thumb drive directly into the front of the DAC, and A/B'd the two, the Thumb has the edge in overall sound quality!
The Audiophilleo gets great reviews, so looking for any tips from the forum... Any tweaks I may be missing? Should I try the same config on a Mac Mini to see if its closer?
I will be continuing to back up the 1000+ cds I have as this journey progresses, so have plenty of time to try options.. If I cant find a way to improve the setup, Ill be back on the forum to seek advice on which Naim product best fits the pieces I have...
Rest of the chain looks like this: nDAC + XPS/ 252+Supercap/ 2 x 135's/ Wilson Benesch Arcs/ and Mitchell Orbe TT.
Simon
