N-stream can't find uniti qute
Posted by: Laurens on 01 August 2013
I would reboot the Naim cute & try again.
Qute - damn auto-correct!
Also try rebooting your router.
Any homes nearby using the same Wi-Fi channel as you?
If you have a Windows based laptop try the following from a command prompt
netsh wlan show all
this will list all SSID Wi-Fi in your area and show channel info
I guess your not based in the uk, have you tried on your iphone removing your existing wifi connection to your access point and rejoining?
also is the Qute on the latest firmware?
Also download an app to your iPhone called Fing (free app) and scan your network and see if your qute is listed
On the Qute if you look under setup (spanner on remote), factory settings, system status then scroll down to IP do you see an IP address ?
After 3 days it rectified itself.... re-connected to another channel on the home network, and connected pc and iPhone to the same channel and now it all works. I did this already, why it worked now and not earlier I don't know! My brother said it was the Ivor Teifenbrun virus LOL
Laurens, glad it sorted it self - but I suspect it will happen again - it suspiciously sounds like poorly implemented multicast (used for discovery) on your wifi. If it happens again I suggest you get an Apple Airport Express and just use it for the wifi for your Ipad and iphone that you run Nstream on.
(If you are already AppleAirport Express then it can't be this ........). But I had a similar issue which I diagnosed to this. No probs whatsoever now using Apple Airport Express as the wifi access point.
Simon
