More buffering issues
Posted by: Popeye on 01 August 2013
Hi all I decided to make my first purchase on Naim label of the WAV 192htz album they have on there and I can't listen to it without constant buffering.
Unitiqute 2 via ethnet and Mybook live nas drive.
Any suggestions?.
thanks
Posted on: 01 August 2013 by RaceTripper
You should be able to stream 24/192 over ethernet. I do it with a ND5 XS.
Maybe your UPnP server is trying to transcode the files and your NAS doesn't have the processor power to handle it fast enough.
Posted on: 02 August 2013 by Popeye
Hi all SI decided to buy some cat5e today and hard wire it from router to uniti. Problem solved I thought but no!  12m of cat5e and it doesn't like it, won't work at all, recognises that everything is connected but fails to connect to nas drive. If I unplug uniti and sit next to router and use 1 meter of cat 5 it works perfict! any suggestions? Cable is sound as I have a cat5 tester!
driving me mad now. Thanks all.
Posted on: 03 August 2013 by jobseeker
I would have thought there should be no problem with 12m to be honest
Posted on: 03 August 2013 by garyi
Is the 12 metre a cross over or patch, cat5 is good upto 100 metres logic would dictate its the ethernet lead.
Posted on: 03 August 2013 by RaceTripper
I am using 100' of Cat6 (Cat5e works as well) going from an Apple AirPort Extreme in one room to my ND5 XS in another. I have no problems.
Sounds to me like an issue with cable or connectors.
Posted on: 03 August 2013 by Rattlesnaic
I had the same problem with a QNAP 112 never could get it to work without buffering.Dumped it and brought a dedicated Vortexbox device, sorted
Posted on: 03 August 2013 by Popeye
Thanks for all your help guys! Problem now sorted. It was infact the cable but not sure why as all was fine with a line test and the qute Evan registered everything but timed out before playing anything And saying source error.
Thanks Ali
Posted on: 04 August 2013 by garyi
A line tester has to run up in order 1 through 8 if its not in order you can still run into issues
