n-stream iOS app not working
Posted by: Partcloudy on 16 August 2013
My n-stream iOS is no longer working since the i-tunes update. Is this a known issue?
Hi, yes its known and there will be a re issued App from the App Store in the next 7 to 10 days once Apple have verified it, apologies, if you update your product to the latest 3.21 software, its on our Web site, the App you have now should work
Hi, I've just updated the streamer ( nd5xs) sucesfully to v3.21 and the app (ipad with ios6) also updated. However the new app does not work well. he racognizes the streamer, however when you choose any (sub)menu or want to select an option, within 3 seconds the prior menu reappears without effectuation of the choice. So it's impossible to use the new version of n-stream and unfortunately there's now way back to the prior version of n-stream. Same happened after installing the app on my iPhone.
do I oversee something??
(rob driessen, NL, who just bought naim (nd5xs, supernait-2 and cd5xs)
I've written to Naim Support, my new N-stream also crashes within 3 seconds even though my firmware for the NDX is at 3.21.01 version. So I'm now using Kinsky and PS Audio E-lyrics to substitute !
