Finding pre-gap takes ages using Samsung SE-208
Posted by: PhilP on 20 August 2013
I was happily ripping using XLD on an iMac when a CD jammed in the internal drive and resisted all attempts to remove it. I tried everything suggested on the Apple site, various Mac Fora and YouTube but nothing worked so I've given up for now...
I then started using an external Samsung SE-208 drive which works fine except that it takes several times as long to find the pre-gaps as the internal drive.  Ripping is just as fast. I wondered whether there are any settings I can change to make the pre-gap discovery run faster but am not sure where to look?
Any help gratefully received. Thanks.
Posted on: 20 August 2013 by murkku
This just happens on some external drives & XLD.
Sadly, I don't think there's a universal fix for it.
Posted on: 20 August 2013 by PhilP
Oh well, I'm 450 CDs in with about the same number to go so think I'll try another type of drive to see if that makes a difference.
itunes disabled - I don't currently use it but plan to revisit when I have more time to play
i'm ripping zero compression flac and then transcoding to wav on the fly.
thanks!
