Hi members
I have downloaded some 24 bit FLAC files (The Beatles), which are stored on my NAS.They play back just great on my UnitiServe SSD. On the iPad it displays the Artwork, Album name and track listings perfectly, but it displays the Genre as 'unassigned', which is not a huge problem, as I thought that I could edit that on the n-serve OS X app on my Mac. The only options it gives are Google, Wikipedia and YouTube? Has anyone tried to edit the metadata, or can't it be done with with n-Serve OS X app?
Posted on: 22 August 2013 by Bart
David, the n-Serve app will only edit metadata of files from cd's actually ripped on the uServe. I use on my Mac the program Gary mentioned; it's called Tag.
I download files (say from Naim, or B&W) to my computer, edit the tags with Tag, and THEN add them to my Naim music share. That is better than editing after adding them to the share and then editing.
Posted on: 22 August 2013 by The Meerkat
Ah, thanks Gary & Bart. I was a bit worried about the site that 'Tag' comes from, but if you guys are using it, then it must be fine.
Posted on: 22 August 2013 by garyi
Its old but well programmed so has worked all these years. Simply drag all the tracks onto it, fill in the just the genra field and then save
TAG only tags flac files.
