N-Stream for Mac OSX
Posted by: Rembrand on 22 August 2013
Is or will n-Stream available for Mac OSX?
Oh how I would love to see this.
It's an App for iPad and iPhone.
I think they should do nstream for atari, and nserve for xbox. But only the original Xbox
And after that they should do the firmware utility for playstation.
Not sure what's with the sarcasm?
I'd love n-stream to run in my laptop...
You should have a Snickers Bar.
Sorry, I thought you may not know that, and was trying to help.
As an FYI, this is not available to US customers.
Not possible for US-based account holders. I know of no way, from within the US, to create a new Apple ID that will access the UK store, or to do so with a US-based ID.
If you do, I'd appreciate hearing it, thanks.
Its not being developed anymore anyway. There was another guy around here developing an app, got as far as windows said he would do mac but that went dry as well.
I found the App on my local app store, but it was removed about 3 months ago.
It was quite buggy, losing connection/servers and would also not release the qute for use with ioS app n-stream.
I ended up buying an ipad which is great, but a ridiculously expensive remote ![]()
Should have got a second hand ipod touch then, you chose to go premium.
I just like fancy naims ![]()
Hi,
is there any way to download it outside of the Mac App Store? I tried almost every country but it seems to be removed completely :,-(
Greetings,
Sebastian
I would also like to find this app. In the meantime, I've had success using Linn's Kinsky with OSX 10.8 and controlling my Superuniti.
Yes I have been playing around with Kinsky for OSX for some time now and basically it can do exactly what I want, but I just doesn´t work right. I can control volume, play/pause and next/prev track but no chance of playing music or arrange playlists etc. and sometimes it just quits working. If there was a way to use Kinsky 100%, that would make me very happy.
Hmm, perhaps I really just ask Naim for the app...
