No Servers, UPnP Compatibility Mode confusion...
Posted by: hafler3o on 24 August 2013
Today I took possession of a SuperUniti, connected it in wired mode, updated the unit it replaced (UnitiQute2) to 3.21, and successfully connected it wirelessly upstairs, I should be happy but it's now 1:30AM and I can't get n-stream to work properly any more.
In the past I'd occasionally get a 'no server' message when navigating the folder tree (I use a WD MyBookLive with Twonky 5.1.9) and have to toggle the Compatibility option in s-stream settings to 'green blob' (whether that means enabled/disabled I can't say). The behaviour of the app. degrades, becomes less intuitive but at least it limps along, rather than just stalling (if left in 'white blob' mode).
Tonight I've been totally unable to get the 'normal' app functionality, despite power resets, static address assignments etc. The Qute and Uniti read the NAS ok, they both navigate & play different stuff at the same time under r/c command, but the Naim app. refuses to acknowledge the network storage unless in green blob UPnP comp. mode (which is frankly slow and weird). Has anyone got any ideas, or shall I delete the app. and just use the r/c in folder mode like I used to before an iPad mini turned up.
