Naim : uniti2 spotify streaming
Posted by: paddyragz on 06 September 2013
The last time this topic was referred to was in "January 23, 2011 6:19 AM"
Which is more than two and half year old post in the below link:
https://forums.naimaudio.com/topic/uniti---spotify
I hope there might be in the tech-world many advances, so that we should by now have an easy way out to stream Spotyfi..
Appreciate your replies in advance ..
A novice Lover of Music
Paddyrags
Posted on: 06 September 2013 by Bart
Hi Paddy, you're not searching the right way I think.  There are threads about how to play Spotify on Naim very often here, and I know of at least one with responses as recently as two days ago.
Lots to read here
Posted on: 10 September 2013 by paddyragz
Dear Bart Can you please paste the links - I appreciate your help.
Lots to read here
Posted on: 10 September 2013 by Bart
Paddy here's a few places where Hook has written about his use of a bluetooth audio device to stream Spotify from an iPad; this would work with a Uniti2 as well
https://forums.naimaudio.com/to...65#29443242081773665
https://forums.naimaudio.com/to...19#29161622618402319
Here's an older thread:
https://forums.naimaudio.com/to...79#19729071279039379
Here's a thread about someone using Sonos Connect to get Spotify:
https://forums.naimaudio.com/to...source-for-unitiqute
The answer is -- none of the Naim hardware support Spotify directly, so you need some other device to send it from a computer or iDevice to your Uniti2.  My vote would be a simple bluetooth audio device.
Posted on: 11 September 2013 by Olek_K
But I just did what someone suggested in the other topic: I connected an iphone to my nac n172's front usb and played one track from itunes library. Then I switched to spotify and pressed play. And now I'm listening to Jon Hopkins and can even see the track info on nac's display! So what happened? I tried this before on my ipad and it wasnt working...
