Uniti-2 input selection
Posted by: pgmvveld on 12 September 2013
Hello,
Recently I bought the Uniti-2 and I am very happy with it.
One question though. Using the remote you can select each of the analogue inputs (cd, radio, aux, etc) directly.
However I have connected my TV and Blu-ray player using the digital connections. So far I have not found a way to select the digital inputs (1 to 4) directly using the remote.
Does anybody have a tip who to do this? I have seen that using the n-Stream app it is much easier.
Ideally I want to add a command to my Logitech all-in-one remote to select the appropriate digital input directly.
Thanks,
Peter.
