Debussy Piano - which recording is recommended
Posted by: Bert Schurink on 19 September 2013
I am intrigued by the piano music of Debussy - I have already the CD from Angela Hewitt and now look to something more complete. It looks like three choices emerge and I would like to hear from you what you would recommend, or perhaps you have even other recommendations. So options I see:
Walter Gieseking:
Jean Eflam Bavouzet:
Alain Planes:
Paul Jacobs - Preludes I & II on Nonesuch (1970)
A remerkable reconding by a remarkable pianist.
More on the Nonesuch site, here...
Jean Efflem Bavouzet is the one to go for.
cheers
aleg
Jean-Efflam Bavouzet's recording is superb.
And, just in case it matters, Bavouzet can be found in 24/96 at Qobuz (although for a price far superior to what you can find the 5 CDs box for, I'm afraid, as it's €14.99 apiece).
HTH
Maurice
Arturo Benedetti Michelangeli, while not anywhere close to complete, is something that every Debussy enthusiast definitely needs.
HTH
Maurice
£24 all 5 CD's in 96/24 at the www.classicalshop.net
cheers
aleg
Not quite, if I'm understanding their site correctly, as the complete box seems to be divided into 2 "compact discs" (scroll down and you'll find a second "compact disc" separately priced). So £48, but it's still cheaper than Qobuz.
Thanks for the tip Aleg.
Maurice
You are right, after 63 tracks of 'CD 1' there starts a 'CD 2' of 41 tracks which also costs another £24.
Sneaky way to display/hide the price of the complete set.
Sorry for the confusion.
Aleg
My vote goes for Jean-Yves Thibaudet: complete piano works on 4 CDs for under £30. Recording is nicely transparent and his interpretations are excellent - nothing too histrionic and with great sensitivity. Only drawback is that his picture on the front cover of vol 1 makes him look like a particularly camp interior designer:
All pianists worth their salt try the preludes at one time or another and there are so many recordings, it's hard to pick a favorite or favorites. However, I consider the etudes the yardstick of a good Debussy player. Uchida tried and failed, there's no getting through it. Thibaudet, on the other hand, makes them sound like prime Debussy. I like Planes as well, he uses a variety of pianos as befitting the pieces he plays. Haven't heard Bavouzet and judging from the opinions here, I really should give him a try.
And out of the left field, let me mention Maurizio Pollini's Book 1 of the Preludes. Fascinatingly played.
For me, the bench mark for Debussy is still Gieseking. He transprots me to that dreamy mysterious far away place.
He even makes the over played, over exposed Clair de Lune sounds fresh and interesting to listen to.
Thanks for all help I just bought: Jean Efflem Bavouzet
You have made a wise choice.
BBM
