Originally Posted by Felix H:
Fretfan, did you also check what happens to your CD5si sound when you switch ND5XS ground to chassis?
Hi Felix, It did not occur to me to test with the CD5si, but I will do. Unfortunately my 3 week old CD player suffered from 3 faults and has shipped back to Naim. Good news is I pick up my new replacement tomorrow, so will test.
My poor CD player suffered with
1. a miss aligned door. It was recessed in by about 5mm when shut.
2. transformer used to hum. Bit irritating when sat powered up but not in use
3. started skipping when playing cds.
I could live with 1 and 2, but 3, made me return the unit.
Hopefully the new one will not suffer from any of these.
I also get a similar effect with the ND5XS when I control it with different access control software, nstream, bubble, kinsky etc..
Using a NAS drive running Twonky,,,
1. Access tracks on ND5XS from front panel - perfect sound
2. Using nstream app on ipad - perfect sound
3. Using Linn Kinsky on Android - perfect sound
4. Using Linn Kinsky on PC - perfect sound
5. Using BubbleUPNP on Android - flattening of image
6. Using Foobar on PC - flattening image
7. Using Mediahouse on Android - flattening image
8. Asset UPNP on PC - flattening image
This is noticable on headphones and speakers. The sound is not poor by any means, but it's like there is less space around the instruments. Same effect as when I change the earth setting.
I also get the same effect with the above software when testing with a Denon streamer too, so it must be something to do with the way the generic software packages interact with the Twonky Server...
???????? weird !!
