Hi Jason - that' good advice, I have heard the Naim xs which i assume is similar to the 155xs given the output the same power. On this basis I guess the leap to the Nap 200 and the Uniti2 from the xs models would be similar (assuming that the impact of pre/power vs integrated combination across both would be similar).
Naim has an awful lot of options. I do wonder for how long they can continue - it can make upgrading a bit confusing...choices, choices, choices!
In part for this reason, and also in part because I don't think i made the best choice with the Qute and my speaker combination despite spending ages thinking about it, I am also going to explore some other options before leaping agin.
The Linn Majik DSM and the Primare i32 both look interesting.
m
Originally Posted by Jasonf:
Hi Minnow,
I demoed the Qute with the 155/152 combo and it sounded very good pulling streams from a U-Serve via ethernet.
But I also demoed the ND5 with the same amp/u-Serve combo and it was better than the Qute. But as usual, I suspect that you have budget issues to contend with. So as far as the 155xs is concerned it is a very fine amp and your plan to integrate the 172 sounds like a reasonable plan to me.
As far as the 200 is concerned, I have not heard it and I am sure it brings a little more of everything to the table, but I am assuming your budget pops its head up at this point, so I would demo the 155 without hesitation and buy in confidence that you will enjoyed it.
Synergy is always good, at least to start with, you can always consider the 200 at a later date.
How the 155xs responds to your ES11's....you should demo for sure, as during my demo, the Qute/152/155 combo drove a pair of Ovator 400's with ease to significantly high volumes in a medium size room.
Jason.
