Streaming podcasts
Posted by: Stephen Pritchard on 30 September 2013
I've a NAS and a couple Qutes and would like to listen to my podcasts thru' the system. (Farming today if you must ask!)
I get podcasts directly through iRadio on my SuperUniti, so the Qute should be the same, with no need for any iPhones.
Hi Bart -
The Bluetooth music receiver I hooked up to my NDS six months ago has done a great job of accommodating guests with iPhone music. All your kids would have to do is turn their phone's bluetooth on and select the receiver from the Airplay menu (in order to redirect output).
Mine is made by Rocketfish, uses aptX for transmitting data, and has a digital optical output. Last I looked, it was $49 at Best Buy. It's also been rock solid for streaming Spotify from my iPad -- not one single dropout.
ATB.
Hook
I've just tried Farming Today, and the last 7 days' programmes are all there, direct from the SU. How cool is that?
Excellent - thanks guys
Do you know a way to save/store a podcast into the preset list?
Get the podcast playing, press the word preset at the bottom left corner and choose the next available number. It's as easy as that, I just tried it to be sure.
So we can have have a preset with a single podcast like a single episode. When this podcast will be old the preset will be useless.
