ndx got one channel working,after upgrade from 3.17 to 3.21
Posted by: ok8888 on 04 October 2013
ndx has got one channle working ,i try phono rca ,it is ok.
any friend can tell me what's problem with ndx
i should bring ndx to the dealer ,but i cannot by some reason.
please help me
 thanks
Posted on: 04 October 2013 by ok8888
sorry ,din sokets has got only one channel,but beside the phono is ok.
Posted on: 04 October 2013 by hafler3o
I'm not an NDX user but maybe verify your DIN lead has not become damaged or gone open circuit. The update is unlikely to cause a loss of channel, did you need to disconnect and/or move the unit before/after the update?
I'm sure some NDX owner will be along soon...
thanks to your reply.ndx is a great source.we could find a lot fun from the ndx.
yes ,before upgrade ,i move  the din cable from the ndx, and finish the upgrade ,i connect agin,maybe i got the incorect position into the din socket。this couse one channel dead?
Posted on: 09 October 2013 by ok8888
i do the factory setting,and only one channel have sound  as the same before.
maybe din sokets is damaged?
can i upgrade again from 3.21 to 3.21?
Posted on: 09 October 2013 by hafler3o
Have you tested continuity of the DIN lead? Can you swap a lead and re-test?
I would not recommend running the 3.21 update just yet, that seems unlikely and no other NDX owner has reported this after s/w upgrade to my knowledge. For support give your dealer a call, maybe he/she can loan a new lead or suggest further things. DO NOT open the box.
