Unitiqute Q
Posted by: DelR on 09 October 2013
Recently got a Unitiqute, however have following question.
As an example, Paolo Nutini, Sunny Side Up, when I chose the album n-stream only shows 3 tracks, 10/10, No Other Way & Chamber Music.
However when I look through all music, the other tracks, such as Candy, are there.
What am I doing wrong?  The music is stored on an LG NAS.
Posted on: 09 October 2013 by Iver van de Zand
Hi DelR,
The issue is most probably with the UpnP server software, not with the UQ or nStream. The latters only "consume" info and data. The only "trick" that you might want to check is to empty the nStream cache.
what UpnP Server is running on your NAS And what version. You might want to do a re-scan or restart of the Upnp
cheers
iver
Posted on: 09 October 2013 by Kevin Richardson
It is possible that the other 7 tracks are not properly tagged.  I've seen this happen many times.
Posted on: 09 October 2013 by Bart
It is almost surely something to do with either (a) the UPnP server running on your nas and/or (b) the way the particular files are (or are not) tagged.
Once you work through these issues, streaming works like a charm!
Posted on: 16 October 2013 by DelR
Thanks for your replies, seem to have got the issue sorted through organising the library though iTunes.
