Unitilite + Synology, an idiots guide.
Posted by: Paul Lite on 13 October 2013
Need a bit of help configuring my NAS. My Unitilite is up and running and can connect to the HD of my PC. I have now set up a Synology DS213J with DSM4.2, set up a shared file called Music and stuck a file in. I've enabled NFS and Windows File Service (workgroup renamed NAIM). But so far the 'lite won't connect to the NAS. So what have i missed, can anyone help.
Paul
Posted on: 13 October 2013 by Bart
Paul have you turned on the server?  It's an "app" that needs to be turned on.  It's called Media Server.
And both the nas and your Unitilite are on your home network?
Posted on: 13 October 2013 by Paul Lite
OK I'll do that now, Yes both are on the (hardwired) network.
Yep, that worked, cheers chaps. Thanks for the help.
You're welcome, and enjoy the music!
