Manual IP Adresssetting Not possible on iPad
Posted by: hicasa on 21 October 2013
As the autoconnection often fails to connect to my Naimuniti 2 via N-Stream App I changed to manual Setting of the iPad Adress. On the IPhone this Works now fine but on the iPad it isn't possible to Set the IP Adress manual even if autoconnection is switched of.
anyone has the same problem or knows how to resolve it?
Posted on: 21 October 2013 by Simon-in-Suffolk
I can set a static IP address on my iPad in Settings->Network.
I am running iOS 5.1.1
Simon
Posted on: 21 October 2013 by Aleg
I'm running iOS 7.02
In the wifi connection settings (click the circled i)  you can choose static instead of dhcp.
In the static tab you can manually set the ip-address and other network settings
cheers
Aleg
Posted on: 21 October 2013 by hicasa
I'm running 7.0.2, so probably i'll have to wait until I can use n-Stream again on the ipad
Thank you! But what i'd like to do is to set a static. Ip adress in the set up from the n-stream App, not in the iPad or iphonesettings
Posted on: 21 October 2013 by garyi
You want to set an IP address for your uniti product? Do that on front of the unit.
I want to Set it like on the pic above under ip adress. On the iPhone its possible but Not on the iPad
Or give a reserved IP-address to your Unity2 in your router/dhcp server.
that way it will also always be assigned the same address. Effect is same as static address and don't have a risk in creating a wrong setting.
Posted on: 22 October 2013 by scillyisles
Hicasa is saying that when he goes into n-stream on his Ipad the autoconnection to his Naimuniti2 fails to connect. So he wants to switch off the autoconnection tab in n-stream and type in the static ip address of his Naimuniti2 into the ip address field within the n-stream app so that it finds it.
I too have found difficulty in getting this to work on n-stream on the Ipad.
Posted on: 22 October 2013 by hicasa
@scillyisles: i exactly meant what you wrote but probably my english is a bit limited...;-)
@WAT: you know where or how to bring it to the Naim support?
