Naim HDX refuses to start
Posted by: Svital on 23 October 2013
My NAIM HDX doesn't start !
I can't hear the disks initializing, and the screen doesn't display anything.
The Naim logo is correctly lighting.
I powered it on and off many times.
Any Idea?
Posted on: 23 October 2013 by Paul Quigley ie
maybe try without the link plug.
Posted on: 23 October 2013 by Richard Dane
I would rather you switched off, try removing and then re-fitting the link plug - then switch on and try.  I have copied this thread to Naim's Tech Support.
Posted on: 23 October 2013 by JeremyT2
Sadly mine did that - back to Salisbury for a major rebuild. Fortunately FOC.
Posted on: 23 October 2013 by Basically Sound
Could be a flat battery. And I am not kidding!!!
Have a word with Naim tech support &/or your dealer.
Tony
