Fidelia and iTunes artwork.
Posted by: Andrew Porter on 02 November 2013
Does anybody know how to configure iTunes artwork to show in Fidelia?
Thanks.
Posted on: 03 November 2013 by sheffieldgraham
Thanks.
What version of Fidelia are you running.
I'm running 1.2.3 on my MacBPro Snow Leopard 10.6.8
If the art work shows in i-Tunes library the Fidelia should pick it up.
Support for album artwork is available from v1.2.0 onwards.
There's a small icon at the bottom LHS of the display page (small square with a triangular arrow.)
Try toggling it. It hides/displays the artwork
Posted on: 04 November 2013 by Andrew Porter
Thanks Graham,works now,I didn't have the iTunes. xml file selected,all good now.
Andrew.
