nd5 xs with nait 5i and unitiserv
Posted by: walsh on 05 November 2013
Hi
Currently have 5i with cd 5i2 with linn majik 109s and wanted to move to hard disk/ server and control music from another room. ( i have open plan across ground floor and into basement) Thinking of nd5xs and unitiserve. How would that set up work? I think that nstream would control the nd5xs wouldnt it?
Also pre wired the house ready for a bus (cat 5) with cat 5 to wall plates and ceiling speakers. If I got the above do you have nay suggsstions on how best to use the wired set up into other rooms. E.g. is there anydecent quality in wall amp that could pick up the streaming fromthe nd5xs and play via ceiling speakers?
Sorry, bit new to all this and spend more time listening than keeping up with technology so hope you can advise.
Posted on: 07 November 2013 by Richard Choong
Other more experienced folks might have other views but if I am correct, you need to use another app called "n-serve" to control the unitiserve. You would use n-stream and set the input to one of the digital inputs which you have connected your US to your 5i with. Volume control unfortuntely is on n-stream but play functions will be via n-serve.
