Twonky and Folder Navigation Mode
Posted by: LCV on 07 November 2013
Hi everybody!
I have a problem using Twonky in folder navigation mode.
When I navigate my library by folder, my folders appear in alphabetical order and this is correct, the problem is that once I select a CD (folder) the tracks order is also alphabetical in this way the original order of the tracks is not respected and this is a big issue specially with classical CD.
I wonder if there is a way to solve this problem.
I also use as UPNP server E-lyrics on my mac ( I have many problems with this solution and this is the reason why i decided to use twonky on my Qnap NAS) but if I navigate by folder using this software, CDs appear in alphabetical order and when I open a folder (CD) the original order of the tracks is respected so this have something to do only with twonky.
I also tryed to use other UPNP streaming software on my iPad but the situation is identical so the problem is not between Twonky and Nstream but is a problem of twonky.
I had a look to the settings of twonky but I did not found a solution!
Some one have a solution?
Tahnk-you
Lorenzo
